Polaris Scrambler 50 performance
Old Oct 17, 2003 | 03:44 PM
adudeinnm's Avatar
Default Polaris Scrambler 50 performance
My boy is bored by the performance of his ride and I've done some checking on the web and have found many references to cutting a cdi wire (as well as sprocket, pipe, etc. mods). We have a 2001 version of the Polaris Scrambler 50. I sure would appreciate it if somebody could point me to a wiring diagram and/or description of the procedure.
Thanks
Old Oct 17, 2003 | 04:57 PM
Scramblur50's Avatar
The best thing to do is search the forum for scrambler 50... you'll get a lot of information that people have already posted.. with that said...
The Scrambler 50s do not usually have a wire to cut... to find out if you do, look above the carb, strapped to the frame with a big rubber band for a box (2x1x3/4 inches or so) with 5 or 6 wires coming out if it. This is your CDI. Pull that box off, and look for a (normally) green wire that comes out of the back of the box (not near the rest of the wires) and loops back in.. cut that wire and tape up the ends.. you're now able to rev wide open... if the box does not ahve that looped wire, buy a CDI off of Ebay that is made for an Eton like this one http://cgi.ebay.com/ws/eBayISAPI.dll...category=11754. Cut the green wire and install it.
After that, get a pipe and a free breathing air filter (Uni, K&N).. then you'll need to rejet the carb (I'm using a 105main).. from there, work on transmission mods (Clutch, transmission gears, sprockets).
Our quad took a 2nd place win in Moto 2 at this months GMQA races.. a similarly set up quad took 1st in both motos that night.
Look at APB-Racing.com and GMQA.com for some video clips with these quads in them.
I've had our quad at 35mph on flat gound with 19T/27T sprockets on it.. there's lots of potential in these little quads.
Bryce
Old Oct 17, 2003 | 08:25 PM
TeamSRacing's Avatar
We've been down that road before too. A couple of points that Bryce didn't mention. First, is the spark arestor removed from the tail pipe? Have you removed the head pipe restrictor? If so, your next step is the CDI. I bought mine based on Bryce's recommendation and I'd recommend the same module. You will be quite impressed as I was on just how much power and speed these rascals produce!
Brad
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
