Raptor boiling over after mods, problem?
Old Oct 22, 2003 | 12:26 AM
Turtler's Avatar
Default Raptor boiling over after mods, problem?
I just got my 02 Raptor back after a rebuilt tranny, added a 11:1 Weisco piston and the Pro Design/K&N air filter kit. I ran in the cinders and noticed the overflow tube from the coolant reservoir had spilled coolant on my rear swingarm after hard riding. I did some more mellow riding in the desert at a later date and noticed a small amount of overspill from the overflow tube.
Is this normal? I never noticed the overflow before the mods listed above. Are you guys noticing this overspill after a high compression piston was added? I was thinking about swapping out coolant for engine ice.
Old Oct 22, 2003 | 12:33 AM
BigScary's Avatar
I haven't had the prollem yet?
Old Oct 22, 2003 | 12:35 AM
howardstern's Avatar
sounds like a headgasket.
Old Oct 22, 2003 | 12:50 AM
Turtler's Avatar
If its a defective head gasket, will I notice coolant in the oil?
Old Oct 22, 2003 | 12:55 AM
FireFly's Avatar
Mine does the same thing. it started light like you said but only got worse. I noticed after hard riding and the temp light would come on but the bottom of the radiator is just a little warm the top was very hot. I changed the thermostat and it helped but still the water temp light comes on. I'm going to flush the radiator and check the water pump. I'll keep you informed
Old Oct 22, 2003 | 01:14 AM
sixsixT's Avatar
Sounds like a head gasket to me too.
Old Oct 22, 2003 | 06:03 AM
Ward660R's Avatar
yup, ditto on the head gasket.
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
yambam13
Jul 4, 2015 01:49 PM
