WB E-Series vs. Supertrapp IDS2
Old Jun 12, 2000 | 03:56 PM
paulgsch's Avatar
After many months of researching silencers for my 2000 400ex I have narrowed down my options to the WB E-Series (slip-on) and the Supertrapp IDS2 (slip-on). I have heard many good things on each pipe. But what I need to know is which one to go with. If anyone has one of these pipes I would like to hear your insite on it. Like which is the quietest, most reliable, and better performing?
I want it to be not to loud (under or around 100db) and for it to last a long time.
Thanks so much for your time and advice.
Old Jun 12, 2000 | 04:20 PM
NVR2L8's Avatar
Well, I'm in the same boat as you, but am trying to decide on either the E-Series slip-on or the entire Pro Meg version with head pipe. If sound is a problem though, I can tell you that the E-Series is loud as heck when running all 12 supplied discs...but only a little louder than stock when running only 4 (the minimum you can run). WB also sells a quiet core insert, but if you're gonna run with the insert "and" 4-7 discs, you're probably better off sticking with the stock pipe when comparing hp vs noise. As far as it lasting a long time, I had an E-Series on my Warrior, and was very impressed with how it fit and the overall quality of the pipe.
Old Jun 12, 2000 | 04:48 PM
400freak's Avatar
I recently installed the full WB Pro-Meg with header pipes system on my 400 and am extremely pleased with the performance so far. I honestly don't think it's too loud but I don't have any idea how many decibles it is. In fact I just ordered 12 more discs to put on it, even my Banshee owning buddy likes the throaty four stroke sound that comes out of it.
Old Jun 12, 2000 | 05:56 PM
426ex's Avatar
out of the 2 pipes the ids-2 is a little quiter
i have the ids-2 and i really like it, went to the p.a. porker run i was the only person that had it of the quads that i seen. is your bike stock or modified. if it is stock and your looking for bottom end power run 8 disc in it.
the more disc the more top end and less bottom end you have. probaly the same way for the e-series. i run 14 disc in mine its a little modified. the pipe sounds really good!!
99 426ex,11:1,port job,web cam,rev box,k/n,dyno jet kit,6 air box vents,ids-2 super trapp pipe,
14 tooth front sprocket = power
Old Jun 13, 2000 | 03:03 PM
paulgsch's Avatar
Oh, and by the way my bike is stock except for a K&N air filter with an outerwear. The reason I am stuck on a disk-type silencer is because I do not want to be screwing with the jetting.
Old Jun 13, 2000 | 05:05 PM
426ex's Avatar
you will still have to mess with it. it is no big deal to change it. with k/n and pipe use a 152 jet. if you get the dyno jet kit you will use the 146.
Old Jun 13, 2000 | 08:00 PM
NVR2L8's Avatar
When I got an E-Series for my Warrior, the instructions that came with it said I probably wouldn't need to rejet if just adding the pipe when running 7 discs. The instructions for a E-Series for a 400EX may be different, but I did have to change the main on my Warrior...think I went up two sizes. Once I got the jetting dialed in when running 7 discs...then I could add or delete discs without seriously affecting the jetting.
Old Jun 16, 2000 | 02:48 AM
paulgsch's Avatar
426ex, If you had to do it over again would you buy the supertrapp again? I just can't make up my mind on these 2 pipes. Do you like the sound of it? How does the sound compare to a WB?
Old Jun 16, 2000 | 11:05 AM
JAKOOL's Avatar
I am using the Supertrapp IDS2 and I love it. I am running with 15 discs, 155 main, K&N w/outerwear, 17 1/2" holes in the airbox, Wiseco 10:1 with XR400 head gasket (143 PSI in the gauge), 450/451 WEB cam, WB rev kit, and match ported intake and exhaust. I USED to have a FMF Powercore IV but like the power, sound , and quality of the IDS2 better.
Old Jun 20, 2000 | 03:52 AM
paulgsch's Avatar
Which of these 2 pipes has the better quality sound (not loudness just good sounding)? And how do these 2 pipes compare to a FMF MegaMax II as far as sound quality and loudness goes?
