What did I mess up?
Old Oct 22, 2003 | 09:56 PM
crazyrc's Avatar
Default What did I mess up?
O.k. the other night I was installing my new snorkel and had the battery removed...not disconnected, just out of the way of the airbox. I went to use my winch tonight and all I got was a click when I tried to spool in. I can't hear anything when I try to spool out. All the connections appear tight. I've never had problems with this winch before and I've used it alot. Please advise me to what I've done or what is wrong. Thanks
Old Oct 22, 2003 | 10:16 PM
LuvDaMud's Avatar
If you have a relay contactor in line with your winch, your switch might be
activating the relay but not making the contact between the batery and
winch. Check the connections at the relay. Usualy the relay is used to
spool in only , unless you have 2 relays. Just make sure all connections
from the winch -switch - relay(if you have one instaled) are connected.
Good luck.
________-_____________________
red prairie 650, 2003
Holeshot module
Dalton springs
26in Bear Claws
full equiped with everything
ltrmc02
Aug 22, 2021 02:34 PM
salixair
Nov 3, 2015 08:25 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
