Fender repair?
Old Oct 24, 2003 | 09:44 PM
Lincous's Avatar
Default Fender repair?
Anyone know what I can use to repair a split in fender on a prairie 360? Any kind of glue, epoxy, etc. that will stick? I would like to place a patch and glue underneath.
Oh yeah, does anyone know the exact type of plastic the fenders are made of? They seem to make glues for different types. Most all of the glues that I have found says they are not made for polypropylene. It would be my luck that the fenders are made of polypropylene.
Old Oct 24, 2003 | 11:37 PM
nyroc's Avatar
I thought they were polyethylene, whatever the case I don't know of a glue that will make a chemical bond to the fenders.
Goop does an incredibly good job at making a physical bond. Rough up the backside of the repair with 24 grit. Use goop with spent drier sheets to keep the goop from running. Put a small amount of paint in goop to match your fender color. Get goop at Kmart, Home Depot, or most hardware stores.
There are fender repair kits available that bond by melting onto you fender. They might work even better.
Do not use hot melt, it will not last. Do not use epoxy, it won't stay.
Old Oct 25, 2003 | 07:31 PM
Lincous's Avatar
Thanks, nyroc. Where can I get the fender repair kit?
Old Oct 25, 2003 | 08:18 PM
nyroc's Avatar
Search google for a product you like.
http://www.urethanesupply.com/dirtbikes.html
or
http://www.plastech-formula.com/MOTORCYCLE.cfm
Old Oct 25, 2003 | 09:01 PM
95Wolverine's Avatar
Give this a quick read....http://www.atving.com/atvconnection/...tic-Repair.cfm
Old Oct 25, 2003 | 10:10 PM
edmondoaaron's Avatar
Have you tried Bondo? or Jb weld? they should work
Old Oct 25, 2003 | 11:05 PM
nyroc's Avatar
Bondo and JB weld are way too brittle. Goop does an excellent job. I haven't tried the plastex stuff yet.
fd24
Jan 16, 2019 08:59 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
89Lt250r
Sep 7, 2015 07:53 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
