A friend just bought an 04 Foreman 450ES
Old Oct 25, 2003 | 11:10 PM
RookWV's Avatar
Default A friend just bought an 04 Foreman 450ES
Is there anything he needs to be on the look out for? Problems, riding surprises?
Thanks for any help.
Old Oct 25, 2003 | 11:15 PM
Harw's Avatar
No problems, no surprises. That is one tough quad.
Old Oct 26, 2003 | 01:37 AM
BSA's Avatar
BSA
The Foreman is the toughest quad Honda makes. It is a mini tank.
Old Oct 26, 2003 | 01:26 AM
Coyotechaser's Avatar
Look out for suspension squeaks! [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Oct 26, 2003 | 09:30 AM
RookWV's Avatar
Sounds like he's gonna be real happy.....suspension squeaks being the only thing? That thing must be like a tank!
Old Oct 26, 2003 | 10:33 AM
Barbarian's Avatar
I have a 2001 450 Es. My started to squeak also. Just spray silicone on the front end parts, went away. Good luck
Old Oct 26, 2003 | 10:50 AM
Yellow650Rincon's Avatar
When I had my Rancher, it started to squeek on one side. So, I took the shock out and greased the bushings and the squeek went away for good. So if it starts squeeking, try that.
Old Oct 27, 2003 | 12:41 PM
action450s's Avatar
I have a '98 and I haven't had much trouble at all. I just replaced 2 front wheel bearings this year which isn't bad after 5 years running, 4 of those with 27" tires!!! He'll have fun with that bike for sure.
Make sure you keep the oil changed per owners manual and get the vavles adjusted after 1st 200 miles and once a year after. Its regular maintenance on a 4 stroke bike.
Old Oct 27, 2003 | 01:26 PM
swampdonkeykiller's Avatar
If he is riding in mud and water all the time, he may wan't to pull his hubs and regrease his wheel bearings every once in a while, or just go and buy the sealed bearings from hilifter and then he will never have to worry about it. A front disc brake conversion is something he should look into if he rides in the mud and water a lot. Other than that he has a solid quad. The only squeeking I had was in my steering stem bushing. I loosened it off and gave it a little grease and it has been fine ever since.
Old Oct 27, 2003 | 08:54 PM
WVRider02's Avatar
they run really well.... All the Natural gas people and otha people who have to drive quads to get places put
Thousand'S of miles on them... So you know there tough and low maintance
