Raptor and 400ex specs
Old Jun 13, 2000 | 05:15 PM
xepathfinder's Avatar
MSRP $6499* xxxxxxxxxxxxxxxNote: available Sept./Oct. 2000
Engine
Type 660cc, Liquid-Cooled, 4-Stroke, 5-Valve, SOHC
Bore x Stroke / mm 100 X 84mm
Compression Ratio 9.2:1
Carburetion 33mm BSR x 2 Mikuni
Starting Electric
Transmission 5-speed, Reverse, Manual Clutch
Drive 2wd
Chassis
Front Suspension Double Wishbone/ 9.1"
Rear Suspension Swingarm / 8.7"
Brakes Front: Dual Hydr., Disc Rear: Disc
Front Tire AT21x7-10 Radial
Rear Tire AT20x10-9 Radial
Dimensions/Other
Overall Dimensions (Length x Width x Height) 72" x 43.3" x 45.3"
Seat Height 33.9"
Wheelbase 49.0"
Ground Clearance 10.4"
Rack Capacity N / A
Towing Capacity N / A
Dry Weight 398 lbs.
Fuel Capacity 3.3 gallons
DC Outlet N / A
Colors Team Yamaha Blue/White, Black/White
SPECIFICATIONS
Model:
2000 TRX400EX
Engine Type: 397cc RFVC air-cooled dry-sump single-cylinder 4-stroke
Bore and Stroke: 85mm x 70mm
Carburetion: 35.5mm piston-valve with accelerator pump
Ignition: Solid-state CD with electronic advance
Starter: Electric
Clutch: Manual
Transmission: 5-speed
Driveline: O-ring-sealed chain
Front Suspension: Independent double-wishbone with Showa shocks, 5-position spring preload adjustability; 8.2 inches travel
Rear Suspension: Pro-Link® single Showa shock with spring preload adjustability; 9.1 inches travel
Front Brakes: Dual hydraulic 174mm discs
Rear Brakes: Single 220mm disc
Front Tires: 22 x 7-10 knobby rad
Rear Tires: 20 x 10-9 knobby rad
Length: 72.2 inches
Width: 45.3 inches
Height: 43.7 inches
Wheelbase: 48.4 inches
Seat Height: 31.9 inches
Ground Clearance: 4.3 inches
Turning Radius: 10.5 feet
Dry Weight: 374.7 pounds
Fuel Capacity: 2.6 gallons, including 0.4-gallon reserve
Color: Red
All
Price &5,699
Old Jun 13, 2000 | 08:51 PM
JumpKing's Avatar
which quad do peolpe represent in racing.
Which is worth buying.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
black_thunder
Sep 22, 2015 07:59 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
