Best Mods for 400EX
Old Oct 28, 2003 | 11:10 PM
Smoothy's Avatar
Default Best Mods for 400EX
what are the best
Old Oct 29, 2003 | 12:16 AM
yellow426's Avatar
best mods . i have a 2001 400ex whitebrothes rev limiter k&n filter dynojet kit fmf full exaust . +2 arms works triple rate shocks . 18rear 20 fronts
Old Oct 29, 2003 | 09:49 AM
SANDMAN430's Avatar
looks like honda got a power gain out of a carb.
Old Oct 29, 2003 | 03:13 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
A bigger carb really helps the 400ex, I would like to get one for mine but I finally got it dialed in and dont want to have to start over again.
Old Oct 29, 2003 | 09:32 PM
fast440's Avatar
how much do you think it would cost to upgrade to the new carb?
Old Oct 29, 2003 | 10:29 PM
SANDMAN430's Avatar
sparks is like a 130 to bore the stock carb, 475 for the fcr39.
Old Oct 29, 2003 | 11:23 PM
Trxoutlawz's Avatar
The best mods for a 400ex will all depend on what you want it for.
For the engine....... You can upgrade the bore up to a 426 without re-sleeving. (406, 416, or 426) any of those piston kits (with gaskets) will run about $110. Any good machine shop can bore out your cylinder for about $50. If you are going to port the head any you will also need to get a valve job done. About $30. $25 for new valve seals. The port work will cost upwards of $200 unless you do it yourself... At the minimum port match your intake to the carb boot and exhaust to the header pipes. (smooth out the steps)
I would also suggest a new cam. About $150. I went with the Webcam 450/451 grind...
I would very much suggest that you get the 39mm FCR Carb.. About $500 with throttle cable.. You must pipe it. I like the DMC $500.
If you want to go to the 440 kit without stroking it. You will be looking at about $500 for the kit and machine work and I would suggest LRD Performance to do the work. Also get a K&N and outerware. about $50. I opened up the top of the airbox lid with and outerware from Sparks Racing. $15.
These are just some basic ideas from me and if you want more detailed info just ask...
My 440 is very strong. I did my own port work and valve job. and all the mechanical work. It is not that hard to do if you can turn a wrench.
If you are just looking for a better ride, put your money into new shocks for the front and have the rear rebuilt....
Old Oct 30, 2003 | 10:14 AM
SupraMan400's Avatar
I allways thought that the easiest and 'most noticible mod for the money' was in fact the addition of a smaller front sprocket. Sure you loose a little top end, but you'll also find yourself shifting from 3rd to 2nd a whole lot less.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
