jetting question
Old Nov 1, 2003 | 09:19 PM
applepie's Avatar
Default jetting question
i know another jetting question.......i have a yfz 450.. i put on a CT pipe with a K&N and air box lid off ..the dealer jetted it for me with a 165 main clip on #3, im not sure about the air screw....in 2nd gear mid way through the rpms it boggs down ...it does not do it in first or 3rd or 4th gear just 2nd........i put the air box lid back on and it was even worse and it bogged in 3rd.....i took the lid off and took off the K&N, it got better but still bogged in 2nd gear at a higher rpm......im at a loss here...any info will help thanks.....
Old Nov 2, 2003 | 04:20 AM
junior11's Avatar
well If the motor pops a little at wide open throttle, you need to go bigger on the jets.
If it boggs, you want to go down. one size at a time.
Ride wide open runs at full throttle, if it doesn't pop, you should be ok, but you can look at the spark plug to be safe. You want it to be a light tan color around the electrode. not bright white
I am at 5000' and I am running 170 main
If I was a sealevel I would go to a 175
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
