400ex??? or 300ex
Old Jun 14, 2000 | 09:32 PM
iceblue4x4's Avatar
What is better for a bigginer. I have rode the 300ex but thank that maybe the 400ex is better for i wouldn't have to upgrade and loose money after getting comftorable or should i learn on the 300ex. thank you
Old Jun 14, 2000 | 09:34 PM
stevie's Avatar
The 300ex would be a much better beginer bike
Old Jun 14, 2000 | 10:59 PM
hondatrx300ex's Avatar
300ex is great beginner to intermediate maybe expert bike with some mods.
Old Jun 15, 2000 | 02:12 AM
300exSTER's Avatar
hondatrx300ex
what does turning your front wheels around do? I see you have it listed on your list. The 300ex in stock form is a great machine to learn on. But you have to understand, the 300ex has ALOT of potential. Cstark has the most trick 300ex i have ever seen. I even hear it can whip a stock 400ex ( ). My 300ex is not quite as modified as chris's but almost there.
Old Jun 15, 2000 | 02:31 AM
300exSTER's Avatar
1995 300ex with:
Suppertrappe pipe, suppertrappe silencer, Dg nerfs, Dg Bumper and Grab bar, Baja Skid plate (rear), K&N air filter (removed air lid sometimes), front/rear XCT holeshot tires, Douglas .190 rims, 3-angle valve job, Trail Porting and polished, Complete Gasket set, Varsha Clutch kit, High Prof. Weisco piston, Cylinder bore 10cc. ...other dumb stuff: Removed handlebar plastic, key switch remounted on left side of gas tank.
Sucks, im still not as trick as Cstarks
Old Jun 15, 2000 | 10:54 AM
400exalltheway's Avatar
my first atv was a 400ex but i also rode alot before, if you feel comfortable get the 400ex
Old Jun 15, 2000 | 09:53 PM
300exster: turning the front wheels around gives you about 2 1/2 inches on each side. its not really a mod but I listed it. it helps the handling. later
Old Jun 16, 2000 | 03:11 AM
wcy2k400ex's Avatar
The 300EX is definetly a better beginner quad. If you have not riden much or any before, you will not want a 400EX. The 300EX has a pretty mellow stock engine, but has a lot of potential. If you want more power on down the road after you have it for a while, there are quite a few things that can be done. If you pick the right modifications, they should give the 300 enough power to suit you.
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
