Buying an ATV Questions and suggestions about what to buy, financing, insurance, etc.
used 250r What to look for?
Old Jun 15, 2000 | 04:44 PM
WOODRIDER400's Avatar
What do I need to look for in a used 250r? What areas do I need to focus on, things that I should avoid or things that are pluses.
Old Jun 16, 2000 | 12:41 AM
THEXOTIC1's Avatar
check for cracks in the frame especially around the swing arm piviot bolt. also check axle bearings and front hub bearings. It u have a compression tester bring it with u and check the compression of the motor. Also check to see if the person did routine maintenance on the air filer and crank case oil.
When the bike is running run through all the gears make sure none of them hang up or dont even shift at all
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
Traci Carnahan Simmons
Aug 9, 2015 03:00 PM
CRamshaw777
Jul 18, 2015 05:46 PM
