Mudlites
Old Nov 9, 2003 | 09:11 PM
RedGoblin's Avatar
Default Mudlites
Can you fit 27" ITP Mudlites on a stock Prairie 650 and have no fender rub or any other problems? If not, maybe 26"?
Old Nov 10, 2003 | 01:08 AM
MURPH1's Avatar
Default Mudlites
Yes 27" will fit with no rubing i run 28"s and
theres no problems.
Old Nov 10, 2003 | 05:30 AM
Code54's Avatar
Default Mudlites
That is correct, 27" tires are not a problem!
Good luck
Old Nov 10, 2003 | 06:51 AM
figs's Avatar
Default Mudlites
yes 27" will fit with no problem i run 27 with no prob. but i also have 2 spacers and 2 inch lift
Old Nov 10, 2003 | 10:25 AM
MikeRhyne's Avatar
Default Mudlites
I just put 27" Mud Lites on C-series wheels on my 04 p700 and they fit with no rubbing but the left front comes within about an inch of the exhaust pipe so without the C-series extra offset I’d probably have some burning rubber in a tight turn. I'm not sure if the pipe is in the same place on a 650 as the 700 but I would guess so.
Old Nov 10, 2003 | 12:58 PM
MURPH1's Avatar
Default Mudlites
MIKE i run 28" on the stock rims on a 650 and there a good 3-4" between the tire
and the pipe. Hope this helps.
Old Nov 10, 2003 | 01:44 PM
MikeRhyne's Avatar
Default Mudlites
Must be a different pipe route on the front of the 650s then. Fortunatally I don't have tire rub its just close.
Old Nov 10, 2003 | 05:38 PM
RedGoblin's Avatar
Default Mudlites
So you can run 28" on stock rims? I thought you had to buy a certain size rim to accomodate the tire.
Old Jan 31, 2004 | 02:33 PM
Xrxman's Avatar
Default Mudlites
I am trying to decide whether to run 27 or 28 mudliteson my p650, since you have the 28s how do you find them??
Hows the bikes stability, and will that large a tire hurt the wheel bearings or drive train? Any info that you can give will be appreciated
Thanks Jeff
Old Jan 31, 2004 | 07:03 PM
Ross650's Avatar
Default Mudlites
Howdy Jeff,
My son is running 28" 589s on his 650. He has a highlifter lift kit which I dont think is necessary. I think 27s are about the right size for a Prairie with no lift kit. Have a goodun!!!!!!!!!!!!!!!!!!!!!!1111
