When should i change my Hub oil
Old Nov 9, 2003 | 11:33 PM
trailrider500's Avatar
Default When should i change my Hub oil
I have had my 03 scrambler for about 9 months now I have changed everything else but the hub oil, When should i change it and do you have to use the polaris stuff?
Old Nov 10, 2003 | 12:01 AM
quadwrench's Avatar
As a rule of thumb - I change all my lubes and grease the quad all at the same time - that way you don't have to wonder when it is time to do what. I use the polaris stuff in the hubs, but aftermarket repair manuals say you can substitute the hub oil with automatic transmission fluid (??). It is a good idea to check the hub fluid (as well as the other fluids) before each ride - if you clean your quad after every ride like I do, you might not notice a little seeping of the hubs, resulting in an eventual dry hub.
Maintenance is cheaper in the long run than major repairs.
Old Nov 10, 2003 | 12:35 AM
BigBadScrambler's Avatar
The manual says every 100 hours. But that stuff gets dirty real quick. I change it about twice a year. It doesn't really hold much in there. You can substitue the Polaris stuff for ATF Type F or Mobil 1 Synthetic ATF (which is what I use)
Old Nov 10, 2003 | 03:06 AM
IsItFast's Avatar
A warning for when you HAVE TO change it: if you are driving and the bike jerks to the left or right (feels like you hit a big rock) then change the fluid ASAP. This happened to me and I replaced with Mobile 1 Synthetic ATF and it solved the problem.
Old Nov 10, 2003 | 03:09 AM
IsItFast's Avatar
And it is best to take the end cap off and jack up the opposite side to help it drain. A lot of dirty fluid will stay on the inside if you just use the fill screw. It only holds a couple of tablesppons so fill it up a little at at time and roll the hub till 4 'oclock; don't fill past that.
Old Nov 10, 2003 | 03:22 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
If you are concerned about it(the front fluid),,,,just change it.
Like BigBadScrambler said,,,twice a year is fine,,,and use the 'Mobil 1 synthetic ATF'.
drain the fluid (even tilting the bike,,,as someone mentioned) fill the fluid (to 4 oclock),,,,then ride a little,,,,and then change again(to clean it out a little).
fill the little hole (in the upright position),,,and then drain,,,in the 4 o-clock position, and plug.
As someone already said,,,,,,,,just do the hubs when you do the rest of the fluids.
it literally takes 4 minutes,,,with all things ready.
Old Nov 10, 2003 | 05:30 PM
Trailblazer250exrexr's Avatar
U SHOULD CHECK ALL UR FLUIDS BEFORE U GO RIDING THATS WHAT I DO. I CHECK MY QUAD OUT BEFORE AND AFTER I GO OFF ROAD SO I DONT HAVE TO WORRY ABOUT IT
Old Nov 10, 2003 | 05:37 PM
Thanks guys for the Input!!!
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
