V Force belt adjustment?
Old Nov 10, 2003 | 02:25 AM
Mudfoot's Avatar
Default V Force belt adjustment?
I have 72 hours on my V and have never tightened the belt or done any adjustments to it yet...is this normal? I run the HPD plain spring, I'm thinking of switching to the Dalton overdrive kit(plate,spring,weights). Any thoughts on this??? Thanks-Mudfoot
Old Nov 10, 2003 | 12:39 PM
XC800's Avatar
Mudfoot:
I have the HPD plain, MAchined primary clutch ( yes the whole clutch!!) and Dalton weights. Check the belt deflection as per the shop manual . I "think" it is 1.06 inches at 10 lbs pressure in the middle of the belt. I found mine to be waaaaay out after about 15 hrs. Could ohave been out from the start, who knows. You can get the 0.3 mil shims from Kawi for the secondary. I think I had a .95 in stock. I removed it . tried 2 .3's now I run a single 0.3 mil shim. A little squeak now and then sitting at idle if it is in forward but the belt goes all the way down the sheaves. At least as far as it can go without machining that funky little device Kawi calls a Helix.!!!!!
Old Nov 10, 2003 | 02:10 PM
KAWIMECH's Avatar
usally when the belt is out of adj it will sqeak on take off or slip during had excell
Old Nov 11, 2003 | 11:59 AM
XC800's Avatar
I believe that would be Waaaay out of adjustment [img]i/expressions/face-icon-small-wink.gif[/img]. I had about 2.5"' of deflection ( more than double what it should be) with no squeak. A squeak would have to be 3" plus [img]i/expressions/face-icon-small-shocked.gif[/img]
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
