Warrior Parking Brake ?
Old Nov 10, 2003 | 06:35 PM
Warrior350ripper's Avatar
Default Warrior Parking Brake ?
Did anyone remove it ..and did u have problems..i know theres a rev limit when engaged what happens if i disconnected it?
Old Nov 10, 2003 | 06:37 PM
warrior007's Avatar
you will have to disconnect the wires to the switch, its the one with the plug down under the plastic, leave the other clutch sensor hooked up or it will only start in nuetral, or will start without the clutch disengaged, either way I like to leave that one on
Old Nov 10, 2003 | 06:42 PM
so i just need to disconnet the wires?
Old Nov 11, 2003 | 12:31 AM
Crotts's Avatar
Yes, all you do is unplug it and remove it. You can also remove the clutch sensor if you want to put on a aftermarket clutch perch, but you got to plug the two plugs that connects the clutch sensor together
1ArmBandit
Sep 8, 2015 08:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
