Whats your Elka ride height?
Old Nov 13, 2003 | 01:01 PM
Enigma's Avatar
Default Whats your Elka ride height?
What ride height are you running with your Elka suspension? Measurements taken at the front engine mount frame crossmember and the crossmember by the footpegs(not including the skidplate). Have you found a height that works best for crosscountry style riding? Thanks!
Old Nov 13, 2003 | 04:24 PM
mt's Avatar
mt
not sure the inches, but lower than stock.
Old Nov 13, 2003 | 10:26 PM
2lman's Avatar
3TV, when are you going to post a pic of the new V?
Old Nov 14, 2003 | 05:20 PM
Kawy's Avatar
Mine is also 8 5/8" just shy of 8 3/4", this height is great for cross country. I race and have hit a few times but only in spots that everyone hits, otherwise these shocks are a must have item for this quad, excellent cornering and much better stability.
Old Nov 14, 2003 | 07:18 PM
chop's Avatar
did you get front and rear,if so how much?
Old Nov 17, 2003 | 02:58 PM
Enigma's Avatar
3TV / Kawy,
I forgot to ask. Is the ride height you specified with you on or off the bike? Does the bike sit level with you on it? Been playing with the Elka adjustments to see what I like best.
Thanks alot
Old Nov 17, 2003 | 05:08 PM
Kawy's Avatar
That is ride heigth with nobody on quad.
Old Nov 17, 2003 | 06:33 PM
mt's Avatar
mt
I have NOT messed with my elka set-up, remember when u order YOU give them weight, type of riding etc. I think my set-up is good, I highly reccommend it.
Old Nov 17, 2003 | 10:54 PM
Kawy's Avatar
3TV where are you measuring from in front and rear to get heights to know if it is level. Also explain how the adjustment works on front and rear. I haven't touched mine, it seemed so much better than stock, but if I can get it turn get even more stable in turns and not bottom out on mid size harescramble jumps I would love them even more!
Old Nov 17, 2003 | 11:32 PM
Enigma's Avatar
3TV,
So your height is 8 3/4 while you are seated and geared up on the bike? BTW, when I initially installed the Elkas the bike was not level as you discribe. I got a lot of rear end bucking when going through whoops fast. I screwed down the "preload" ring on the fronts to level. Talk about a world of difference when leveled! Amazing. I measured unloaded and I am at 10 1/2 ride height (no rider on bike). I want to go lower to get more small bump sensitivity. I think your 8 3/4 height makes a whole lotta sense.
Thanks for the info!!
Enigma
