scrambler battery won't hold a charge
Old Nov 15, 2003 | 08:52 AM
skratch's Avatar
Default scrambler battery won't hold a charge
Could it be my battery is going to crap? can someone tell me how to check the electrical to see if the engine is charging the battery while it is running?........I am not sure if I have a bad battery or a bad electrical system......
Old Nov 15, 2003 | 08:59 AM
dodgepower's Avatar
Hey brother is it on a big scrambler or little one. If its on a big one its the battery bro. If its little one might wanna check stator.
Old Nov 15, 2003 | 01:14 PM
skratch's Avatar
it's a 2001 scrammy 400 2x4, 2 stroke..............u thinks it's the battery?
Old Nov 15, 2003 | 02:20 PM
upnort's Avatar
For me my starting problems have been the battery 4 of 5 times. 1 bike, 1 sled, 1 atv, 1 car and had a car where it was the voltage regulator.
While running at about 200 rpm's you should have about 14.4 volts on the battery but if the batt is bad enough it could load the charging system and make it liook like charge is not good. Battery is normally the cheapest route.
Old Nov 15, 2003 | 02:40 PM
TahoeRider's Avatar
I just had the battery replaced under warranty for my 03 Trailboss because it would not hold a charge.
Old Nov 15, 2003 | 04:09 PM
Bubba297's Avatar
upnort, did you mean 2000? I think you did. Skratch, how old is the battry? I have had them go better than 3 years without a problem. But if it's questionable at all the battery is probably the culpirt. The regulators tend to be pretty stout pieces.
Old Nov 15, 2003 | 09:54 PM
stumpjumper400's Avatar
try filling it back up with distilled water then charge it and try again. if you test it with low water it will show a charge but wont hold a load. just an easy fix if this is the problem
bzdok1234
30
Feb 23, 2016 01:55 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
