race gas with High comp piston on pred???
Old Nov 16, 2003 | 08:59 PM
Hozed's Avatar
Default race gas with High comp piston on pred???
while im fixing it up.. do i need to run ras gas with a new high comp piston?
Old Nov 16, 2003 | 09:35 PM
trailrider500's Avatar
Yeah you will, high compression needs a higher octane you might be abel to get away with 92 octane pump gas....
Old Nov 16, 2003 | 10:11 PM
Hozed's Avatar
ya thats what i was wondering... in only requires 87 right now.. but i figured id hafta run a much higher octane.. for all you people wit the HC piston.. let me know please.
Old Nov 17, 2003 | 05:25 AM
XxDumontRaptorxX's Avatar
If its 11:1 you should run around 94, I get good results with an 11:1 on a 94 (mix 90 with 110 race gas until its around 94 octane) or you can buy some octane boost with 92 octane and that should be fine
Old Nov 17, 2003 | 07:29 AM
Hozed's Avatar
i prolly wont do it then.. there is no place to get it around here... the one place i can is a yamaha dealer... 40 dollars for 5 gallons.. i aint in the mood to spend 80 - 100 dollars a month on gas for my quad as well as my truck!
Old Nov 17, 2003 | 08:41 AM
You can run it on high octane pump, but if you ride the **** of out it, and the quad really starts too heat up, you may get some pinging. I tried pump gas at the dunes once, after about 8 runs up comp, i got pinging, so I bumped up the octane and then it was fine. They make Octane boost for about 5$ a bottle that treats up to 25 galons of fuel, good for +3 octane (so they say) Alot cheaper than getting race gas if you ask me.
Old Nov 17, 2003 | 09:51 AM
propolaris's Avatar
hozed 40 bucks for 5 gallons is way to much for race gas. I get b35 gas wich is 101 octain for 15 dallars for 5 gallons. if tou have a phillips 66 around ther you might beable to get it threw them. i have 12.5 comp. piston in mine got it from hpd. they said you need run atleast 97 or more.
Old Nov 17, 2003 | 04:58 PM
Hozed's Avatar
well the only place i know is that dealer... VP red... its a rip off... but some morons buy it... most people running it in stock quads or bikes...
2quiker
Mar 22, 2022 08:36 PM
Sep 1, 2015 01:45 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
