Neeed help....out of gas
Old Nov 17, 2003 | 04:10 AM
99tjrockcrawler's Avatar
Default Neeed help....out of gas
My friend's speed ran out of gas the other day and now we can't start it...Help!!!!!!!
Old Nov 17, 2003 | 12:26 PM
thomez's Avatar
Running anything fuel injected out of gas is a worse deal than a carb. I've learnt that the hard way running my Celica out of gas a few times back in the day. No wonder my grandpa always was on my rear about having enough gas. Whatcha supposed to do when you don't have a fuel gauge anymore but test the limits? lol.. Ok, so here is what I'd do....
#1 - you probably have fouled a plug messing with it, or drained your battery. Make sure it is putting out at least 12.8 volts or get it on a trickle charger for a while to get it up to spec. Check your plug and change if necessary.
#2 Starting procedure. From what I've read, here is what you should do. Turn on key, wait 15 seconds, tap starter switch, turn off key. Wait 10 seconds, turn on key, tap starter switch, turn off key. Wait 5 seconds, turn on key, start it up. From what I've read that is the way to do it, might give that a try.
Keep us updated.
Old Nov 19, 2003 | 11:25 PM
WISTECH's Avatar
If you ran out of fuel there is a good chance you fouled the plug by cranking it with very low fuel pressure. Check da plug out.
Old Nov 24, 2003 | 11:37 PM
well guys, we figured it out....First let me say dont ever let your dale run out of gas and try and keep starting it with no gas. He took it in under warrenty and they found the crankshaft seal blown and flywheel broken(dont know how) but they said this could happen if it backfired real bad which it did when he was cranking on it.
Old Nov 25, 2003 | 12:32 PM
thomez's Avatar
Holy crap a Cannondale with a warranty?!?!
LOL
BEC300ex
Mar 12, 2013 02:15 PM
gyroman
ATC 3-Wheelers
Aug 23, 2012 10:31 PM
James Roles
Jul 20, 2012 06:20 PM
02YFM660R
Sep 28, 2011 11:15 PM
quad biker
Sep 17, 2011 04:37 PM
