Small, low-pressure-tire, air compressor?
Old Jun 17, 2000 | 08:03 PM
TwoWives's Avatar
Anyone have a recommendation on one of these, that's small enough to carry in the Rancher storage area (and uses the power outlet)? Or do you recommend a one-time use canister-type thing?
Thanks, Nathan
(And you have recommendation of where to buy it on-line?)
Old Jun 17, 2000 | 09:48 PM
hot_shoe_cv's Avatar
You might try J C Whitney's web page. I have a small one I carry in the storage box on the rear rack of my KQ. I don't recall where I got it at the moment.
Old Jun 18, 2000 | 01:04 AM
minehunter's Avatar
I have found through personal experience that the small compressors are nice, but if you pop a bead you will need either the little CO2 type of tire filler or an aerasol can of that fix a flat. the small compressors do not have enough volume to reseat a bead. Even with the aerosol can we had to use a racheting type of tie down to put around the tire tread to help push out the side walls.
Old Jun 18, 2000 | 03:45 AM
atving's Avatar
I read somewhere that Sam's Wholesale club had a deal one it comes with the compressor some plugs and other stuff for $20, I think I am getting one for fathers day heavan knows I have dropped enough hints hehehe
Old Jun 18, 2000 | 03:59 AM
azrob's Avatar
The problem with the compressors is: they fall apart from the ATV's vibration. I used to own a Grizzly, and first had compressors (I had to keep replacing them) then switched to a compressed air tank.
ReconBayou
Oct 31, 2022 05:37 PM
firsttimerider
Sep 26, 2015 01:49 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
