looking to wire a cigratte lighter 400ex
Old Nov 17, 2003 | 03:10 PM
saltydog's Avatar
Default looking to wire a cigratte lighter 400ex
i want to wire the ciggarett lighter on ,my 400ex so i can use a air compresure i have no clue were to start
Old Nov 17, 2003 | 06:03 PM
420EX's Avatar
i spliced my "wheelie lights" to the black/silver spotted wire coming off the voltage regulator (aluminum dealie with fins behind tha battery) with a quick connecter from autozone, works great!
Old Nov 18, 2003 | 07:57 PM
saltydog's Avatar
j
Old Nov 19, 2003 | 12:14 PM
95wolv's Avatar
You can wire directly off the battery for best power output,use at least a 12 gauge wire,and put a 10 amp fuse in line(or whatever the compressor is rated for). then pick a spot out of the way and mount a marine type cig lighter (it has a watertight flip cover) and you will be ready to roll. if you put it near the handlebars, you could use it to power a gps for long rides,or other auxiliary items.
Old Nov 19, 2003 | 12:43 PM
boogerbub's Avatar
Salty, props on an absolutely amazing idea. No sarcazm. I had a horn on mine for a while, but it got water-logged and never worked right again so I took it off.
JP
Old Nov 19, 2003 | 02:43 PM
fartman's Avatar
do you think it would work if you spliced into a head light wire, and when you want to use the cig lighter, turn on the lights to activate the power?
Old Nov 19, 2003 | 03:19 PM
95wolv's Avatar
The headlights are only rated for 30 - 60 watts, I think you would probably fry something if you tried to tap into the lighter wires used for the headlights, a compressor pulls a good amount of amps,especially when first starting up, so I would stick to coming off the battery with heavy wire directly (don't forget a circuit breaker or fuse.) make sure the fuse is close to the battery, so any damage to the hot wire that may short it out will kill the power near the battery, and not leave the wire hot where it can short on the frame.
Old Nov 19, 2003 | 03:40 PM
saltydog's Avatar
95wolv great idear that probily what im gonna do i say the piece in dennis kirt should be here tommorow i will put it in an let u now thanks
later
saltydog
Old Nov 19, 2003 | 03:41 PM
MikeCer's Avatar
My wife's Prairie came with one built in and I blew the fuse on it the first time
I used it trying to connect a air compressor to it. It was just one of those
small air pumps, I cant remember what size fuse it was, but I guess it not
ment for any real use other than lighting cigarettes
Old Nov 21, 2003 | 05:29 PM
saltydog's Avatar
mission complete wired it to the battery with a inline fuse connector but the piece in the front of the storage tube in the back of the 4 wheeler still have room to put stuff in it thank for the info
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
