Does anyone know why my LT won't run.
Old Nov 18, 2003 | 08:38 PM
NichelsonRacing87's Avatar
Default Does anyone know why my LT won't run.
I have a 1987 LT250R and need some advice on why it won't run. I had it running perfect then all of the sudden it just quit, but isn't blown up. First i figured the reeds, so i replaced them, then i had the carb cleaned and checked out. After that i found that it is getting fuel and has a spark. An ATV repair specialist told me it is either the coil or stator or it doesn't have enough compression. Anyone have any comments or advice for me.
Thinking of selling it. Message me or you can use my AIM screename. Payed 2,500 with close to 800 dollars invested. $2,500 if anyone is interested.
Old Nov 18, 2003 | 11:01 PM
Hondabeater's Avatar
I know exactly why your quad wont run. I answer this question alot in this Forum, Its because its a suzuki, lol aka susucki
Old Nov 18, 2003 | 11:09 PM
Z400dude's Avatar
Out of all people you should know hondabeater you own a yamaha, aka junk
Old Nov 18, 2003 | 11:31 PM
LT250Rodney's Avatar
Hondabeater, what a waste of your time and his. Post something constructive or dont post at all. I hope your Yami breaks and people jerk you around when you need help.
As for your problem, if you own a service manua, I *believe* it gives the resistance specs for the electrical components, give em a shot with the old ohm-meter and see what you find. Im not 100% on this so i may be wrong.
Sorry if I cant be of more help.
Old Nov 19, 2003 | 10:35 PM
LT250Rodney,
I read my manual about the wiring, but i don't want to mess anything up, so i'm having it looked over by a friend of mine who repairs quads and bikes. I was told it was either the coil or a compression problem.
Old Nov 20, 2003 | 12:01 PM
Duneaddict's Avatar
IF YOU CAN'T POST SOMETHING CONSTRUCTIVE, PERHAPS YOU SHOULD GO BACK OUT TO THE PLAYGROUND AND PICK YOUR NOSE WITH THE OTHER SECOND GRADE CHILDREN!!!
BOOGER EATING MORON!!
Old Nov 20, 2003 | 12:05 PM
Duneaddict's Avatar
NR87;
I can't imagine you wanting to sell your quad just because of a technical difficulty... Do some testing and figure out whats going on with it.
a motor needs essentially 4 things to run.
Fuel
Ignition source (Spark) induced at the correct time
Air
and a compatible environment to sustain combustion (Sufficient compression)
If you've already verified spark and fuel... air is a 'no-brainer' unless a rag or somethings still in place from a recent disassembly.
Borrow a compression gage and check it...
Let us know what you find out?
Good luck!
Old Nov 20, 2003 | 10:56 PM
Duneaddict,
thanks for the advice, but another reason i'm selling it is because all i have is problems with it. It's an awesome quad when it's running right, but it has parts from 3 different quads on it so whenever something breaks i have to take the parts with me and see if the parts shop has something to work on it.
Old Nov 21, 2003 | 11:00 AM
evhwg's Avatar
i have to also check my coil. my bike has been hard to start cold lately. fouls plugs to often to. this is after a total rebuild and did it before the rebuild to. so i am going to have to learn how to use an OHM meter.
Old Jan 14, 2004 | 09:20 PM
Supernut's Avatar
Just push it around. It won't be any slower than it was but you'll save alot of gas money[img]i/expressions/face-icon-small-happy.gif[/img]
