Am I stupid or something? Sprocket help please!
Old Nov 19, 2003 | 09:37 PM
MedievaL's Avatar
Default Am I stupid or something? Sprocket help please!
Allright, why the $$#@%$# can't I get the nut off that holds the front sprocket on. I've tried for a couple of hours the last 2 days and have had no,luck. I bent the lock washer down around the nut. I went all the way arounfd the washer and bent it completely flat against the sprocket. I soaked the nut with wd40. I've used a 3 foot breaker bar and can't get it off. I think my problem is that the sprocket is turning enough while I am trying to loosen the nut that I am not getting effective torque application to break the nut loose. I am trying to loosen the nut with the chain still in place and trying to use the rear brake to keep the sprocket from turning while I try to break it loose. Is there a more effective method for holding the sprocket in place while I try to loosen the nut?
Any help would be appreciated. I could take it to the local shop but they said they would have to keep it 3 days to do the swap for me because they are backed up. I don't want to do that if I don't have to.
Old Nov 19, 2003 | 10:04 PM
Customfabandweld's Avatar
The problem you are having is with your chain. You can't get enough torque on the nut because your chain is stretching and the fact that you need a quick, hard blow on stuck nuts, to break them loose. My suggestion is to remove the chain, and secure the sprocket against the frame, with a homemade device. Make sure whatever you make grabs both sides of the sprocket, 180 degrees apart. If you try to wedge something against the sprocket, on one side only, you could cause the case to crack. Finally don't push soft on the breaker bar, give it a good hard shove, or use an impact, if you have one available. I hate to ask, but you inspected the thread to make sure you are turning it the right way? Good luck, let us know how you do!
Old Nov 19, 2003 | 10:15 PM
MnFriesen's Avatar
if you heat it up it you might be able to break it free more easily too. get like a hand held propan torch....one of the little ones
Old Nov 19, 2003 | 10:24 PM
Just be careful you don't fry your oil seal, though.
Old Nov 19, 2003 | 10:46 PM
95Wolverine's Avatar
I don't know what kind of bike you have, but is it possible that it is a reverse thread nut?
Just a thought.
Ride On.
Old Nov 19, 2003 | 11:42 PM
MedievaL's Avatar
It is a Lakota. I can't actually see the threads but I am almost positive it has standard direction threads (not reversed).
MedievaL's Avatar
It is a Lakota.
Old Nov 20, 2003 | 12:34 AM
Chris142's Avatar
Them nuts are tight! Yer best bet is a 1/2 inch air impact gun.
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Canamaniac!
Sep 15, 2015 06:19 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
