Sport Quads Discussions on sport quads.
YFZ450 High Compression piston???
Old Nov 21, 2003 | 01:17 PM
QUADMXR's Avatar
Default YFZ450 High Compression piston???
Has anyone put the high comression piston in there 450 yet?? If so then how much gain did you see?? Was it all on bottom end?? Do you have to run 50/50race gas? Or do you have to run 100% race fuel?? Thank You
Old Nov 21, 2003 | 01:23 PM
gnd111's Avatar
It already has 11.9/1......... If you go higher then 100 octane is plenty...
Old Nov 21, 2003 | 06:56 PM
QUADMXR's Avatar
Im talking about the 13:1 compression piston from Yamaha GYT-R kit??
Old Nov 22, 2003 | 07:34 AM
MickeyDunlap's Avatar
You can read about a 12:1 470cc kit that does more then a 13:1 std bore and still runs on pump gas in the Feb. or March Dirtwheels.
Old Nov 22, 2003 | 11:22 AM
ShadyRascal's Avatar
Mr. Selector put the 13-1 piston in his, I think at the same time also did the cam mod and a pipe. So I couldn't say on the piston itself, but I rode that set up and WOW did it work.
Old Nov 22, 2003 | 01:48 PM
QUADMXR's Avatar
Hmmm......How much does the 470 Kit run comapard to the 13:1 Kit?? I just want to get alittle more out of my quad
Old Nov 22, 2003 | 11:26 PM
Well the 13-1 "kit" is just a piston, gaskets and labor to install. The 470 is going to be the same plus boring out or sleeving, whatever it takes to get that many more cubes.
Old Mar 10, 2004 | 07:00 AM
wildtxn's Avatar
I'm running the 13:1 in mine and i run pure race fuel. VP motorsport 103 unleaded 99 octane. The power is all the way through the curve. you could run vp c12 and mix it, but the key is to get right
at around 100 octane for the 13:1.
Old Mar 13, 2004 | 02:21 AM
madracing's Avatar
there are alot of us doing the 470 kit now. but the kit is incomplete without the porting.
Old Mar 15, 2004 | 02:44 PM
maddog56's Avatar
i was pretty sure that selector was running a 467 bore. at least, he was after it blew up on him.
