650 dyno runs
Old Nov 21, 2003 | 01:45 PM
REDKAW650's Avatar
Default 650 dyno runs
has anybody dynoed their p650 I have a couple dyno runs in my picturs and wondered haw they compare to others
Old Nov 21, 2003 | 01:59 PM
newbeatle's Avatar
thanks for the pics of the dyno run... I had wanted to run a base line, before I started modifying mine... turns out the closest dyno is 3 states away... so... no dyno runs for me... I time distance runs down my drive way, to compare increases in power... best I can do ...
welcome to the forum RED
Old Nov 21, 2003 | 02:12 PM
REDKAW650's Avatar
the best it's done is 5.95 300ft run with timing lights
Old Nov 21, 2003 | 02:20 PM
alltoys's Avatar
Bernie,
The pics are not to clear just to go over the second pic is your machine putting out 40 HP to the rear wheels and with the 2 colors was this with stock setup run then the modified run. Was there a before and after?
Old Nov 21, 2003 | 02:26 PM
REDKAW650's Avatar
41rwhp they are both modded runs in the second one the green one may have been reving to high on the dyno as it was faster at the drags
Old Nov 21, 2003 | 02:51 PM
NovaKaw650's Avatar
Bernie - was the first pic showing two runs with and w/o the module turned on?
Old Nov 21, 2003 | 02:53 PM
REDKAW650's Avatar
yes it is
Old Nov 21, 2003 | 03:04 PM
trx450's Avatar
Old Nov 21, 2003 | 03:05 PM
newbeatle's Avatar
Bernie... can you list the mods done to the quad, between the 1st run, & the second ??? thanks WAM
Old Nov 21, 2003 | 04:44 PM
truckracer's Avatar
Originally posted by: newbeatle
thanks for the pics of the dyno run... I had wanted to run a base line, before I started modifying mine... turns out the closest dyno is 3 states away... so... no dyno runs for me... I time distance runs down my drive way, to compare increases in power... best I can do ... welcome to the forum RED
I don't have a dyno available either, so I am going to try one of these. GTECH
