CONVERSION CHART FOR FUEL MIX
Old Jun 19, 2000 | 11:06 AM
WOODRIDER400's Avatar
Does anyone have or know of where I can get a conversion chart for fuel to oil mixes.
i.e. 32:1 = ? oz. of oil per one gallon of gas.
Thanks for your help.
Old Jun 19, 2000 | 11:36 AM
Tree Farmer's Avatar
Why not make your own with graph paper and a ruler? Gallons on one axis; ounces on another. Draw lines of interest and label them, "20:1," "32:1," "40:1," and so on.
Tree Farmer
Old Jun 19, 2000 | 12:10 PM
I would if I knew what the conversion was. Does 32:1 mean that you should use 32oz. per gallon?
That is where I am confused
Old Jun 19, 2000 | 12:18 PM
THEXOTIC1's Avatar
To make it real simple Get a ratio cup it has all the markings on the cup for pre mix and also has CCs so u can measure your crankcase oil. It is fool proof. I take the empty 1 liter bottle and measure for six gallons then i marked the bottle so i can refill. The ratio cup gos up to 2 1/2 gallons It is only $4 Worth every penny
Old Jun 19, 2000 | 02:02 PM
Deej's Avatar
Woodrider400,
To answer the question directly:
32:1 is 32 parts gas to 1 part oil. So if you use 32 oz of gas you need 1 oz of oil. If you use 32 gallons of gas, you need 1 gallon of oil.
ie. 32:1, 40:1 etc are just ratios of gas to oil.
1 US gallon = 128 oz
Therefore, for a 32:1 mix:
32 oz gas needs 1 oz oil
128oz gas needs 4 oz oil
or 1 gallon of gas needs 4 oz of oil
or 5 gallons of gas needs 20 oz of oil
Once you figure out the amount of oil required, write it on your gas cans as amount of oil per gallon. ie. I usually write "32:1 = 4oz/gallon". This way it is easy to multiply by the number of gallons you are putting in.
In US gallons:
20:1 = 6.4oz/gallon
32:1 = 4oz/gallon
40:1 = 3.2oz/gallon
Hope this helps,
DJ
Old Jun 19, 2000 | 02:53 PM
Thanks deej, that is what I have been asking for all along.
Old Jun 20, 2000 | 10:49 AM
Thor's Avatar
Good job Deej.
ltrmc02
Aug 22, 2021 02:34 PM
blueandy88
Sep 7, 2020 03:11 PM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
