need advice
Old Nov 26, 2003 | 01:31 AM
1fst700's Avatar
Default need advice
if i install a set of cams into the vforce will this be a noticible increase in power Thank you
als what types of cams are out for the 700.
Old Nov 26, 2003 | 01:45 AM
Prairiewrench's Avatar
Default need advice
It depends on the cams as to how much of a gain you will feel! Call Webb Cams and talk with them about what they have out or call Mickey Dunlap at 4 Stoke Tech and see what he has to tell ya!
Old Nov 26, 2003 | 01:49 AM
1fst700's Avatar
Default need advice
Thank you. I talked to Mickey today about a 785cc kit just a little much right now. Just wondering if cams would help. Thank you.
Do you like the 785 kit?
Old Nov 27, 2003 | 02:21 AM
Default need advice
Mickey is a great guy, his service is second to none!!!! As far as the 785 kit goes, when I was breaking it in I was going around 18 mph and cracked the throttle a little bit, the Prairie stood straight up,,, shocked the heII outta me! The sound is different (good), the power is unbelievable, very crisp and responsive! I had a problem with the guy who did my machine work locally and ended up with a cracked sleeve, it had nothing to do with the kit, just a machine work problem. I got the new sleeve but sent my heads to Mickey and I'm waiting to get them back right now. As soon as I get it all back together and get some time on it I will post my results! I can't wait, I got a little taste of the power and I'm now starving for more! LOL! [img]i/expressions/face-icon-small-happy.gif[/img]
As far as just cams, yes, they do make a differance! On my 02 650 Prairie I installed the Penland cams alone with a HMF exhaust, jetting, and airbox mods. I test ran it for top speed before installing the parts, 67 mph,,, then after the mods,, 71 mph!!! I have set up a few Prairies and a couple V Forces and the cams along with the proper other mods to go along with them makes a great improvement! The cams I would get from Webb tho, they make a great product and it's cheaper than getting them from Penlands!
Old Nov 27, 2003 | 02:44 AM
1fst700's Avatar
Default need advice
About how much do the cams cost? Also what other mods help the cams? I have Pro-Circuit T-4 duals, HPD plain spring (primary) black spring in secondary,also have stock jets and filter K&N on the way, stock snorkle is removed, I cut out the vents in the hood last night, 20 inch RAZORS on rear.
Just for looks ITP C-SERIES wheels.
DG Fat Series grab bar.
AC nerf bar black webbing.
Would post pics but don't know how!!!!!
I live in Kentucky elevation is about 800 to 1100 ft!
Thanks for all the help!!!
Old Nov 27, 2003 | 03:17 AM
Default need advice
You have a good exhaust! I would get a snorkel on it that faces forward and up towards the radiator cap to take advantage of the vents being cut out in the hood, this will give you a ram air effect! I did this with a radiator hose that had just the right bends but I have no idea what the hose is, I found it laying in the shop! The intake snorkel Diamond G (714-299-3865) has out is a very nice one! You should also do some rejetting, with the exhaust and the opened up airbox you need more gas! You also might want to get ahold of Dale at Dalton Pro( 902-897-3333), he has done some really impressive stuff with the clutching for the V Force and he owns and races one! He may be able to give you some better ideas as to what you can do to gain some power. As for the cams price, I'm not sure,,, you should call Web Cams and they will be able to help you out there! Their number is (909-369-5145).
Old Nov 27, 2003 | 05:38 AM
1fst700's Avatar
Default need advice
Thanks
You have been most helpful![img]i/expressions/face-icon-small-smile.gif[/img]
I am planning on getting my dad a P700 for Christmas mostlikley will get it Friday!!!!
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
