Will new 400EX plastic fit onto 89 250R
Have a 89 250R that I converted to a 350RX and would know like to try and install new 400EX plastic onto the machine. I tried a search and came up with nothing. If someone has a link to a previous thread, please post. Otherwise any info regarding this fender swap would be appreciated. I plan on installing a new seat as well.
Banshee front fender mounts work. you will have to cut out a place for the kicker to stay, cut out the gas tank cover so you can get to your gas tank and you would have to get some kind of headlight assembely nto put in that hole.
From what I have been told, 400ex plastic will practically bolt right on the 250r.
Although you will need the 400ex seat and the gas tank cap doesn't line up exactly so the hole will need to be trimmed. Two spacers will be needed for the side panels, the 400 frame is a little wider than the 250r. Also the front latch of the seat base will need to be modified.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
