doing engine rebuild need help
Old Dec 1, 2003 | 11:05 AM
sledgehammer650's Avatar
Default doing engine rebuild need help
My friend sunk his bayou 300. I know it needs a set of rings. It was making a ticking noise. I checked the vavles and there ok so i pulled the motor apart. The piston didn't look bad and the end gap on the rings where .023. the rod felt ok side to side and up and down. I can't find where the ticking is coming from. Do you think it could be the cam chain. Someone who does this more often would see this more and know it right off the bat. I not that lucky but i did look at it real hard, then pulled a few hairs out. So please help.
Old Dec 1, 2003 | 10:06 PM
macgiver's Avatar
a bad sparkplug connection can make a tapping sound
Old Dec 2, 2003 | 05:04 PM
would it be worse when it cold. It had sit up for about 3 mths before i started it and it was pretty load at frist thenit got a little quiter.
slowgsxr97
Mar 18, 2022 03:40 AM
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
ghost civic
Jul 27, 2015 03:15 AM
hondarider1234
Jul 21, 2015 11:53 PM
