front end kick in on the Scrambler 4x4
Old Dec 1, 2003 | 07:20 PM
jimthescramblerguy's Avatar
Default front end kick in on the Scrambler 4x4
Hey there
When I drive my scrambler in 2 wheel drive and the tires are spinning the front end kicks in and turns my handlebars. are you guys having the same experience? Could there be a prob?
Thanks
Old Dec 1, 2003 | 07:28 PM
trailrider500's Avatar
When is the last time you changed your hub fulid? Sounds like one of your hubs is sticking.... Try driving in reverse for a while sometimes that will fix it....
Old Dec 1, 2003 | 07:54 PM
scramblinho's Avatar
I have a 2002 scrambler that has the same exact problem. and I have drove in reverse many times trying to get it to stop but the fornt left wheel still engages when the rear wheels spin. help us please befre I tear the front end up.thanks
Old Dec 1, 2003 | 08:07 PM
Have you guys changed your hub fuild?
Old Dec 1, 2003 | 09:51 PM
Bustedparts's Avatar
I would check to see if your hub has been properly torqued.It's sounds like it is loose and when you go into a corner hard it is engauging the hub buy rubbing on one side of it.
Old Dec 2, 2003 | 12:03 AM
fishslab's Avatar
Check your air pressure as well as fluid. Mine was doing that when one of my tires got a little low. Once I got all the pressures back to recommended pressure my problem went away. Air pressure changes the overall circumfrence of your tire and can through off the ratio from front to back.
Old Dec 2, 2003 | 03:16 AM
rumblefish1973's Avatar
I had one side that had that problem until I damaged the CV joint and had to rebuild that side... Once I changed the fluid and torqued everything back down it was too tight the first time and engaged erratically... I backed it off some and it works great now... So change your fluid and re-torque that side and that should fix it!
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
