Do i have to Port & Polish for this?
I want to add a piston kit 11:1 std. bore Je or Wisco kit
I have a stage 2 hotcam and kibblewhite valve spring on the way
1.will the piston kit be a good one for my raptor along with the accessories below in my signiture, pipe filter jetted ect?
2.how much total hp on average will my raptor have with the stage 2 hotcam and the 11:1?
3.Will i be able to tell a difference with the hotcam stage 2 and the 11:1 piston kit?
you would be looking at a noticable difference. that is for sure.
you should have around 55hp if you go with the port and polish.
and the port and polish will definetly help, but i don't figure you have to do it.
Hey AustinOneal, here is a video clip a of a Raptor with pretty much the same stuff you are looking at beating a CPI drag piped, 34mm carbs, ported, high comp banshee. This Raptor made low 50 HP with mild porting and low 60's with more agressive porting.
Raptor
Ray
Raptor
Ray
