NABER HOLESHOT MODULE
Old Dec 5, 2003 | 10:34 AM
JDE700's Avatar
Default NABER HOLESHOT MODULE
I have a Naber Holeshot Module, the instructions say to splice in the red wire with the brown and blue dot wire on the P700. Problem I have no brown and blue dot wire. Can some please tell me where to hook the red wire from the module. I assume the canada P700 has different color of wires.
Thank You.
Old Dec 5, 2003 | 10:42 AM
alltoys's Avatar
Did you look at the wiring loom going into the fuse block just down on the left from your cdi ( igniter )? It is pretty simple if the wiring is not the same from US to CDN. There is a black wire with white stripe that comes from the battery negative side it is the same negative wire that runs into the fuse block. All you need to do is find a positive wire in the wiring loom that goes to the fuse holder this way the power is turned off when you turn off the ignition. Of course the blue wire goes the cdi pink wire after it is cut. The brown wire with blue dots is the positve in the loom it is possible the color code is different from one side of the border the other.
Old Dec 5, 2003 | 11:22 AM
JDE700's Avatar
Alltoys, I have a P650 with the dg holeshot can I hook up the red wire with the same wire used on the P650.
Old Dec 5, 2003 | 12:17 PM
alltoys's Avatar
JDE700,
Not quite sure of your question. I am not familiar with the wireing code of the DG holeshot. I imagine there is a red for positive, black for negative, and another color to join onto the pink wire from the cdi. Both positive and negative wires are found in the wiring loom going to the fuse block with a circuit tester you can find what you need. All the holeshots will fit neatly by the fuse block when done.
Old Dec 5, 2003 | 01:58 PM
bbertram's Avatar
Do search about this, I had the same problem. Or call Ted at Naber, he will help you out. The problem is the wires are different colors from the US and CDN version of the P650/P700.
MikeyBoyesq
Nov 27, 2020 02:44 PM
STLyamwar
Jul 25, 2020 04:44 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
ltrmc02
Jul 22, 2015 04:50 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
