83 xr 80 wont start
Old Dec 5, 2003 | 02:17 PM
ddman's Avatar
Default 83 xr 80 wont start
i have an 83 xr 80 that was bought new for me in 82. i have put new rings, head gasket, had head redone, crank, and seals put in. most of it i done. i replaced the points and new plug rode it about one hour and it started spettering and cutting out and finally died. now it wont start, it backfires like it is hitting but wont start. could i have burned the points or would it be water? i also run real sluggish untill you get it wound out then i comes on strong and would stay there untill you let off the gas. any help will be appreciated . i planned on given this to my daughter for her birthday.
Old Dec 5, 2003 | 02:43 PM
Harw's Avatar
When you put the points in do you clean them? There is a film on the points. If you do not clean them they will burn right away.
Old Dec 5, 2003 | 04:19 PM
sickmojave's Avatar
I agree I would start at the points. make sure they are clean and the gap is right. when was the last time the carb was cleaned? that would be my next step.
Old Dec 10, 2003 | 09:46 PM
cluby's Avatar
Hey all your right sounds like you have a points problem but replace only it's ok to spray off with some brake cleaner or contact cleaner just do not file or sand honda points
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
