Eliminate Raptor Reverse Rev Limitor.........
I was in a spot last weekend where I wanted to back up an embankment but I couldn't because of that d@mn rev limitor on my Raptor. I know there are aftermarket product available to eliminate this annoying limitor. Has anyone done this and if so how does it work and how difficult is it to install?
Thanks.
Thanks.
I have a 02 grizzly and it also has that annoying rev limiter. The rev limiter on the griz works through the reverse light. I don't know if the raptor has the same wiring or not but on the grizzly, under the left side panel is a green wire with a white stripe. I unhooked this wire, then grounded the female end to the motor. Now when i am in reverse the rev light stays out and there is no limiter. Now i have all the power i need in reverse.
Pretty much the same with a Raptor, ground the green/white wire under the front sprocket. Your Reverse light won't work but it's a quick, cheap way to get rid of the rev limiter.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
