Pred 90- waterproof
Old Dec 10, 2003 | 11:43 PM
kyxplorer's Avatar
Default Pred 90- waterproof
Has anyone found a way to keep the flywheel area dry and clean of mud. At the riding area in our county, by the end of the day the 90 will die( starts loosing spark) because of dirt build up in the flywheel area. You can wash it out in the creek but then you have to put it in the hauler to let it dry out by the heaters before he can ride again. I have to have the air flow due to the mod's( 0.030" off head, 25 over pistion, ported, polished/wided exhaust port, WRH race pipe,dual stage reeds, clutch kit, single throttle cable, running premium and 40:1 klotz, 30 pilot and 92 main jet), this is an 03 model. any ideas?
thanks
hunt
Old Dec 11, 2003 | 01:55 PM
BradLoomis's Avatar
The air vent cover over the fan can be replaced with an 04 style that has been changed to a snorkle. I also got some vulcanized roofing rubber that is about 3" wide X 1/8" thick, and I cut it to 1" strips and seal off the plastic cover seams. Haven't had a problem since I have done that.
Old Dec 11, 2003 | 08:00 PM
kyxplorer's Avatar
Brad,
thanks for the tip, i'll get some of the roofing rubber and try it. Does this have adhesive on the back or how would i attach it? i saw the 04's yesterday and was wondering how it would work. thanks for the input.
hunt
Old Dec 16, 2003 | 02:34 PM
BradLoomis's Avatar
The 04 cover replaces the 03 shield. So it is a direct replacement with a single screw. As for the volcanized rubber, I haven't found much that it won't stick to.
Old Dec 16, 2003 | 09:53 PM
Trx250Time's Avatar
My Brother well wanted a Predator 90 He found out all the bad stuff and decided he was only 8 and he wanted to wait until he was more into it so for Christmas he is sticking to Mighty Beans and Wrestling toys.
I promised he would regret himself
BYC
Sep 25, 2015 02:10 PM
Alex G.
Sep 19, 2015 06:34 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
