Need a little help
Old Dec 12, 2003 | 06:40 PM
Ty2's Avatar
Ty2
Default Need a little help
Wolverine owners with the 424 Select - when you are in 2WD and you slam on the back foot brake to stop do you get a wheel skip or bad shudder or vibration from the back of the quad. After following the advice from you guys on the board - I checked the brakes the rotor and pads and finding nothing wrong I figured it was in the rear diff. because when I put it on a lift I could feel a little play when I turned the tire back and forth. I took it to a dealer repair shop - they had it a week - they said the play in the diff. is normal and nothing is wrong with it -they said it's just the rear tires skipping when you slam the rear brake - because they couldn't get it to do it in 4wd. Does this sound right ?
