Fuel System
Old Dec 14, 2003 | 04:47 PM
DRod's Avatar
Default Fuel System
I'm having some problems with my 6x6 400L carb. It will idle fine but once you put down the hammer to it
it start to bog down then quit.(likes it's out of gas) I blew through the gas filter so it looks like it's ok.and I have taken the carb. off and cleaned it. (looked ok) I have played with the air screw and idle adjustment with no luck.
I'm pretty sure the jetting is ok due to the fact that it used to run good. What would you guy's check for at this point .
Old Dec 14, 2003 | 05:46 PM
fishslab's Avatar
Default Fuel System
How are the reeds? What kind of compression you got on it? How old is your 6x6? THe thing I'm getting at is, is it time for a top end rebuild?
Old Dec 14, 2003 | 07:05 PM
Traildog's Avatar
Default Fuel System
What colour is the spark plug? If it's white/ish maybe the intake boot has a hole in it.
Old Dec 15, 2003 | 05:49 AM
DRod's Avatar
Default Fuel System
I'll check these things out tomorrow BUT .... Do you think with 1200 miles you would need a top end already? One thing I did noticed is gas in the airbox? (maybe air gettting in or floats stuck?)
Thanks for all your input will check it out and report back.
Old Dec 16, 2003 | 05:56 AM
DRod's Avatar
Default Fuel System
well after rebuilting the carb and adjusting it. I found out my sparkplug was bad.
I guess, I should not over think these 2-stroke. Anyway thanks for all your input. It did help
STLyamwar
Jul 25, 2020 04:44 AM
COFatboy
May 2, 2020 12:06 AM
Jul 23, 2015 11:46 AM
Aitch
Jul 21, 2015 09:40 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
