400 Scrambler HELP!!!!
Old Dec 15, 2003 | 02:00 PM
Coachmc1's Avatar
Default 400 Scrambler HELP!!!!
I have a 98 400 Scrambler that just died on me. It has a pipe, clutch kit, and .20 over. I wanted to try a bigger carb so I put a 38mm flatslide on it and modified the air box. It seemed to be running great for about 30 min and it died and will not start. I have fire to the plug and the gas line flows fine. I even put the old 34mm back on it and still no luck. The reeds look okay also. Any Ideas?
Would low compression cause this?
Is having a bigger carb going to be a problem?
Thanks
Old Dec 15, 2003 | 02:05 PM
CED's Avatar
CED
Well the 38 has a reputation of having a very lean midrange.You will most likely have to do a compression test,under 100psi and it will not start.Was this 38 on another 400 ? Oh, welcome to the forums.
Old Dec 15, 2003 | 02:40 PM
ScramblerX's Avatar
Yep, I bet you where running too lean and cooked the piston. Was the ceramic on the spark plug white? When setting up the new carb its always best to go very rich with it and work your way down, doing plug checks often.
Old Dec 15, 2003 | 02:45 PM
Coachmc1's Avatar
It was new in the box. Main jet is 230, needle on 3rd clip.
Old Dec 15, 2003 | 07:00 PM
Crawdad's Avatar
Sounds like it's Wiseco time.
Old Dec 15, 2003 | 07:10 PM
BoonDockBasher's Avatar
Sounds like u fried it.......
Old Dec 16, 2003 | 10:12 AM
Coachmc1's Avatar
Well Boys, after deeper research and a compression check, I have a 10 inch crack in the crank case just below the head bolts. So I quess a rebuild is soon to follow.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
