Polaris 4wd and chains
Old Dec 17, 2003 | 02:56 AM
scavanau's Avatar
Default Polaris 4wd and chains
Can't find this specific answer in a search so...
Am I risking any damage to the 4wd system if I run chains only on my rear tires? Anyone experience any long term or short term effects?
Old Dec 17, 2003 | 03:17 AM
fishslab's Avatar
I can't imagine any harm that could come. All it will do is give you better traction in the rear and cuase it to go in awd less. In my thinking it will cause less wear on the awd system.
Old Dec 17, 2003 | 04:36 AM
WileyCoyote's Avatar
Shannon, I don't think it's even an issue. Go to the Polaris web site. Polaris only sells chains for the rear tires.
Old Dec 17, 2003 | 05:39 AM
scavanau's Avatar
Yeah I noticed that. Looking to be safe now, rather than sorry later. Thanks.
Old Dec 17, 2003 | 09:15 AM
Polarisboy2's Avatar
What are you planning on using the chains for? I was looking at getting them for the plowing I do, but everybody told me I wouldn't need them. We just had our first storm last weekend and they were right didn't have any problems whatsoever with traction. At least nothing AWD couldn't get out of. Jay
Old Dec 17, 2003 | 04:00 PM
I bought tire chains through the Polaris web site. They're still sitting in the garage, collecting dust. I had no idea the Sportsman had so much traction and power. We'll see what happens later on when the snow gets deeper and wetter.
Old Dec 17, 2003 | 04:24 PM
scavanau's Avatar
I need them for plowing. Ice forms at the end of the driveway and I need the extra traction in that area, especially after the plow comes by... I wouldn't need the chains if it weren't for the ice problem.
Old Dec 17, 2003 | 07:09 PM
HOSPORTSMAN's Avatar
Just my 2 cents, but you will be suprised at what you will be able to do without chains. But if you do
use them just be careful, It probably goes without saying but those chains can be real dangerous at high
speeds. Chains should only be used at slow speeds so you will have to take them back off before having any
real fun after plowing. If those chains ever came off at high speeds it will most definetly be hard on the quad and possible the rider. I usually find that chains help the best on dirt/gravel driveways. They tend to spin more
on pavement or concrete and can ruff up a nice driveway.
Old Dec 19, 2003 | 02:30 PM
clumsy2222's Avatar
i bought a set of V bar chains from cycle country with my plow. used them once and won't ever again. they were a PITA to put on and they came off easily when i spun the tires. the biggest thing that will help is to throw 2 or 3 80lb sand bags on the rear rack, you won't get stuck.
Old Dec 19, 2003 | 05:12 PM
Did you use any rubber bands on the outside to keep them tight? They should stay on if tightened correctly.
