Axle nuts?
Old Dec 17, 2003 | 09:17 PM
badcompanyracing's Avatar
Default Axle nuts?
How do u get the axle nuts off to remove the carrier?
Old Dec 17, 2003 | 11:16 PM
Farmr123's Avatar
Default Axle nuts?
Is it a concentric or non-concentric machine?
Old Dec 17, 2003 | 11:18 PM
quadwrench's Avatar
Default Axle nuts?
If you're talking about the Rear Wheel Bearing Carrier -
Jack the quad up, pull the wheel off, pop the dust cover off, pull the cotter pin, slap the axle nut off with an impact gun, pull the hub off - then pull the bottom 2 carrier bolts out, the top carrier bolt off, and the carrier will come off in your hands (maybe - if the inner bearing race is not stuck to the shaft [img]i/expressions/face-icon-small-smile.gif[/img]).
OR (the harder method):
Pop the dust cover off, pull the cotter pin, break the axle nut loose with a breaker bar, jack the quad up, pull the wheel off, remove the axle nut, pull the hub off - then pull the bottom 2 carrier bolts out, the top carrier bolt off, and the carrier will come off in your hands (maybe - if the inner bearing race is not stuck to the shaft [img]i/expressions/face-icon-small-smile.gif[/img]).
Old Dec 17, 2003 | 11:19 PM
quadwrench's Avatar
Default Axle nuts?
Sorry, Farmr, didn't mean to jump in on you [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 18, 2003 | 07:43 PM
Default Axle nuts?
thnx quadwrench
Old Dec 18, 2003 | 11:53 PM
Farmr123's Avatar
Default Axle nuts?
No sweat Quadwrench. The reason I asked is because the Concentric drive machines have a snap ring to deal with, to remove the axle from the carrier, wheras the non-concentric do not. The techniques are similar, but a little different because of it.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
raman8tor
Sep 20, 2015 07:35 AM
1000gade
Sep 9, 2015 04:41 PM
bmark0610
Sep 7, 2015 09:42 PM
snowolson
Aug 31, 2015 03:51 PM
