Scrambler/Wolverine
Old Dec 18, 2003 | 10:09 PM
Troyer23J's Avatar
Default Scrambler/Wolverine
Any thoughts on combining a Scrambler and a Wolverine to get a dual a-arm 4x4 polaris quad? Think this would work?
Old Dec 18, 2003 | 10:57 PM
OffRder15's Avatar
Hey Polaris, what do you think? [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 18, 2003 | 11:09 PM
Troyer23J's Avatar
If only they would listen.
I want to make this happen, I have never seen it. Need to find a wolverine frame first. Could buy one from yamaha, but thats a bit pricey to just cut it up.
Old Dec 18, 2003 | 11:56 PM
420EX's Avatar
check ebay, you should be able to find one for under $300
Old Dec 19, 2003 | 12:01 AM
Troyer23J's Avatar
I have been watching ebay for a month or so, no luck yet. If anyone sees a wolverine frame please let me know. Thanks!
Old Dec 19, 2003 | 12:14 AM
BigBadScrambler's Avatar
Any reason in particular why you want a Wolverine drame? Wouldn't the duel a-arm setup on some of the Utes work as well?
Old Dec 19, 2003 | 12:18 AM
Troyer23J's Avatar
It may. I dont really know much about Yamaha's. I figured that since the wolverine is sporty that it would be a good choice. It has 7.1 inches of travel, stock, and can be increasedto 9 or so. If other frames are the same then they would work too. What are some other 4x4's with dual a-arms?
Old Dec 19, 2003 | 12:23 AM
I believe that the Artic Cats have duel a-arms. I think that Suzuki and Kawasaki may have them too? The big problem that I see is getting the hub to work with a duel a-arm. The hub is what controls the 4wd system. It would require some major fabrication. A 2wd would be a lot easier. But, when there is a will, there is a way.
