Your fav.....
What is your guys favorite set up for the raptor, and why????
For example:
A stock bore 12:1 w/ Stage 2 cam, aftermarket valve springs, port and polish, and so-and-so exhaust is my fav. setup because.......
or
A Sparks 690 10:1 w/ Hi Rev Cam, aftermarket valve springs, port and polish, sparks exhaust, and 35mm fcr's are my fav. setup because.....
I was just wondering your opinions and thoughts.....
For example:
or
My first big bore and fastest is a Craycraft port and polish,cylinder bored out to a 668 with a 11:1 piston,stage 1 hotcam ,craycraft modded stock carbs,stock valves and springs,Yoshimura comp full exhaust, so basically a mild 686 is what i call it, I pulled alot of ponies out of this thing from tunning and it beats alot of bikes with the works,im scared to try something diffrent or bigger because it runs so good now for a dragger and a duner.. I think the least is to get the 39mm fcr's to make it really scream,but these stockers from craycraft are doing a hell of a job..I can get into more details on the build but i have a few tunning secrets that cant be revealed,that's what it takes to be the fastest..
I wouldent trade my build for any other builder out there,youll be asking question after you see me run a few times.. and for the price i saved a bunch of cash...
