race head
Old Dec 19, 2003 | 07:12 PM
JEFFROE's Avatar
Default race head
any body out there make any big gains running a race head on a larger bore ds motor? my machine is now making less power with the shim under work and bigger cams an ever befor. i have lost 10-12 hp going shim under and pami race grind cams? im sure that somthing happened during the machining procress for shim under to cause this but i'm back to making 45hp @ the tire and pissed[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Dec 19, 2003 | 07:20 PM
DuneMe's Avatar
Default race head
Something's not right.
I am running the Pami Race 1 cams, Pami Race Head (larger valves), Shim Under and the 760. I haven't put it on the dyno but, it COOKS!
Which cams are those? Race 2's or their full race cams?
I have a buddy with the Ron Wood Race 7's on his stock bore and I just don't know about them.
Something doesn't sound right. Do a lead-down test and see how things look. Depending on the dyno you should have 55 (we have a real conservative dyno here) to 70 HP.
I don't know much about the MBRP but, could things be clogging up on the a$$ end? I put the Ron Wood on the same time I did all the other work. I know I need to get the jetting right but, I sure can feel the power! I think I had 52 HP before (again, our dyno is low). I probably have about 60HP on the dyno we use now.
Old Dec 19, 2003 | 07:33 PM
JEFFROE's Avatar
Default race head
this things runs just flat and lazy, i ran a stockish kfx 700 and got beat bad!!! samcoe you there??
Old Dec 19, 2003 | 07:39 PM
PUSHINTHELIMIT's Avatar
Default race head
WOW! Something's definatly very wrong!
Old Dec 19, 2003 | 09:52 PM
JEFFROE's Avatar
Default race head
duneme, i have pami's #4 RACE CAMS intake and exhaust, how much was you'r pami race head? is it and stock head worked over or a new part all together?
Old Dec 19, 2003 | 10:30 PM
SANDMAN430's Avatar
Default race head
a guy out here has the 109's and his runs pretty good.
Old Dec 19, 2003 | 10:45 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Default race head
[img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
Old Dec 19, 2003 | 11:49 PM
ironrod's Avatar
Default race head
Race grind cams -- are we talking .450 lift? ding ding ding.
Old Dec 20, 2003 | 12:18 AM
DuneMe's Avatar
Default race head
I got the head as a re-worked item from Pami. It was about $1k + valve sprins, buckets, shims, cams, etc.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Sep 15, 2015 02:42 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
Sep 1, 2015 01:45 AM
