Vforce brakes
Old Dec 21, 2003 | 09:30 PM
mudAGoGo's Avatar
Default Vforce brakes
Hi all. I just picked up my VForce, Polaris, and Suzuki for our family Christmas. I took each for a spin and noticed the brakes on the VForce do not seem as good as the other two. Can you guys with VForces' lock the rear wheels? How do your brakes feel?
Thanks
Old Dec 21, 2003 | 10:07 PM
TRX500's Avatar
Mine lock-up very easily without much pressure.
Old Dec 21, 2003 | 10:12 PM
MacV700's Avatar
My V will stop on a dime. I am surpised at the brakes being able to stop 800 pounds as good as it does. There is a rear brake adjuster on top of the rear swingarm. If you can't lock the rear brakes, turn the wingnut a couple times.
Old Dec 21, 2003 | 10:36 PM
MikeCer's Avatar
mine also will lock up with either the hand or foot break.
sounds like you just need to adjust them
Old Dec 22, 2003 | 05:44 PM
mudAGoGo's Avatar
made some adjustments and here are the results. turned each wing nut clockwise 6 full turns, 12 half turns. I kept count because the wingnut turns 1/2 revolution per adjustment.
this has resulted in the rear tires locking sometimes when using the foot pedal. so far when using the hand brake for the rear i have had not rear wheel lock. if i use both at the same time i can get it to lock pretty much on demand. has this been what you guys have experienced?
may adjust a bit further, but i am suprised the dealer would let the bike out the door like that and/or the factory has the brakes so loose like someone else mentioned.
Old Dec 22, 2003 | 05:45 PM
mudAGoGo's Avatar
one other question. i presume that both the hand lever and foot pedal brakes control both brakes on both rear tires?
Old Dec 22, 2003 | 11:07 PM
HappywithVForce's Avatar
I really don't use the brakes that much. But when i did have to do a hard stop once, I thought they could of worked better. I have not touched them yet....I think i will adjust them for future use.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
