need more power
Old Dec 22, 2003 | 09:50 PM
plowboy's Avatar
Default need more power
ive got a sportsman 500 2001. the other day i went to ride and the engine didnt sound right and lacked power. top speed was only 30 mph. ive checked the spark plug and replaced it. it acts like a vacum leak but i cant find one any help would be apreciated.
Old Dec 22, 2003 | 10:29 PM
Hozed's Avatar
thats odd... sorry i cant help.. burnt belt maybe.. i aint sure what a burnt belt really does.. but i think they make it slower and more sluggish.. but i dunno about that sluggish!
Old Dec 22, 2003 | 10:42 PM
Traildog's Avatar
We need more details, what does it sound like? When, hot cold always? What colour is your plug? Have you done a compression test, if so what was it, wet & dry? That's enough to get us going.
plowboy's Avatar
thanx anyway hozed. i know it aint the belt. ive got plenty of low end power. its the mid and top end that im having problems with.
Old Dec 22, 2003 | 10:49 PM
plowboy's Avatar
the compresions fine. i put a new plug in didnt help. got good spark. it just acts like a vaccum leak. engine temp doesnt matter. it does hav a little backfire when you rev it in nuetral. hope this helps. thanx
Old Dec 22, 2003 | 11:24 PM
Traildog's Avatar
Usually when it backfires it is due to a lean mixture. Run it in the higher rpm range and check the colour of the spark plug. If it's white it is very lean, grey is lean rusty brown is what you're looking for. If it is lean check the carb boot for holes or loose clamps. Check the air box cover for a good seal, a bad leak will cause the same symptoms. The 500 will not run without an airbox lid unless major rejetting is done.
Old Dec 22, 2003 | 11:37 PM
pudljumpr's Avatar
I know it sounds dumb, but check your air filter. I've actually seen air filters so dirty, that the machine runs rich and floods out at 1/2 throttle. You can also have rich backfires...so it's hard to tell. If you have never changed your jetting, check the air filter. Maybe you have and just didn't mention it, but look at it, clean it, replace it, whatever..and see what happens!
Old Dec 23, 2003 | 12:33 AM
Traildog's Avatar
<FONT face=Verdana size=1>pudljumpr, that is an excelent point, I have seen that too.</FONT>
Old Dec 23, 2003 | 12:37 AM
trailrider500's Avatar
I dont know if i am right but, This sounds like a worn cam to me... A friend of mind had a problem like this turned out the cam was junk.. It would backfire and had little or no mid and top end... Polaris has been known to have some bad cams... Pull the rocker cover and take a look while your at it check your valve clerance as well...
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
