pred valves
Old Dec 22, 2003 | 10:57 PM
badazzpred's Avatar
Default pred valves
on our predators after the break-in do we have to do a valve adjustment or not?
Old Dec 22, 2003 | 11:04 PM
Hozed's Avatar
Default pred valves
i didnt.. and i dont know of any that have.. my buddy works at my dealer.. and he said i shouldnt have too...
Old Dec 22, 2003 | 11:42 PM
pudljumpr's Avatar
Default pred valves
No, shouldn't have to. But I would have them checked once a year if you put lot's of miles on it!
Old Dec 22, 2003 | 11:54 PM
badazzpred's Avatar
Default pred valves
hey hozed and pudjumper Im stumped here help me please I have a new 04 pred with 6hrs on it all that is installed and all that will be installed is a k&N drop-in and a wb slip-on Im at 6000feet or less should I rejet or not and if so what should be done exactly thanks guys?
Old Dec 23, 2003 | 07:31 AM
Hozed's Avatar
Default pred valves
your just below 6000??!!! where at?
i am at sea level.. when i had my k&n drop in and biggun slipon with 6 uni vents.. i had a 162.5
if i had those installed on my quad.. my dealer told me i would need a 155... that seems low to me.. and since your at 6000 ft.. and the higher the elevation the higher the jet.. i think.. i would put a 162.5 or 165.. you might wanna even get a 167.5..
i am not sure how much elevation changes jetting.. but its a start for ya atleast
Old Dec 23, 2003 | 09:42 AM
Maddog419's Avatar
Default pred valves
I live at 5000" I would start with a 150 main, on the valves. If you had to kick this mach over, i bet more of us would be checking them more often.
later [img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 23, 2003 | 09:49 AM
stryder's Avatar
Default pred valves
i'm no expert on jetting but wouldn't you need to jet lighter at higher altitude. Less oxygen, so why ad more fuel?
Old Dec 23, 2003 | 12:36 PM
badazzpred's Avatar
Default pred valves
I am not exactly sure what elevation I am at I live in the southeastern part of wisconsin all I do know is it is 6000feet or less Im not even sure if I have to rejet at all like I said the only add ons on the machine are a WB slip-on and a k&N panel drop-in filter with the stock box, lid, snorkel, oh and a polaris tach/hrmeter/
Old Dec 23, 2003 | 05:50 PM
Hozed's Avatar
Default pred valves
ya thats makes sense...
as for starting at a 150? the machine is stock at 150... since stryder is right.. higher altitude lesss jet needed id go with a 155 or 157.5
PS.. you are supose to rejet with just the k&n...
but for some reason polaris says you dont need to rejet with the WB slip-on... i called WB myself to ask how much power it gave.. and they said 1-2 HP.
Old Dec 23, 2003 | 08:02 PM
Maddog419's Avatar
Default pred valves
Stock is supose to be 150 on the main. But I would open it up to see any-way. And if the 150 is still to rich,(check plug 1st) you can drop down to 147.5 But that would be the leanest IMO that you would need to go. Thier's a 142.5 Also. If you need more help on it email me.
later
