Please recomend ATV Trunk
Old Dec 24, 2003 | 12:11 AM
FamilyGuy's Avatar
Default Please recomend ATV Trunk
Can someone recomend a ATV storage Trunk that will fit my 04 Magnum 330. I Like the Kimpex Deluxe, but how easy is it to install and how quickly to un-install the unit. Anyone who sells them at an reasonable price. Thanks.
Old Dec 24, 2003 | 01:49 AM
scavanau's Avatar
Most all storage trunks are fastened merely with little straps that keep it attached, but not necessarily in place. To answer one part of your question they attach/detach in seconds with a series of little insignificant plastic buckles. I had to put a piece of uni-strut inside the bottom of my trunk, then drilled holes through the bottom of the trunk dropping bolts through to another piece on uni-strut located under the rack. Keep this in mind if you plan to ride 2-up. I felt this was the safest way to tote my son along. After some time, even with the buckles routinely adjusted, the trunk wants to slide when its weighted and the bike off canter. The original fasteners are fine for just toting your stuff...
I found Cabelas to be the most reasonable.
Old Dec 24, 2003 | 12:02 PM
Firedawg's Avatar
I have a MoToVan trunk. They are pretty much the same as the others. However I had to use the supplied u bolts to attach it to my rack. Was using the strap and buckle system but no matter how tight you got the straps it still moved around a little. Well the problem with this was the underside of the Polaris rack ( the plastic ones ) are not round but hollow and flat and that edge eventually cut the staps. You may want to protect aginst this if using the straps.
Old Dec 24, 2003 | 03:04 PM
upnort's Avatar
I went with the polaris one, it has a disconnect system that fits through the longer grab holes on rear rack then trist 90 degrees. Good seal and is lockable. Big enough for chainsaw, gas amd oil. Is bit pricey at about 170 but I got mine as a demo for 125.
Old Dec 24, 2003 | 07:18 PM
401's Avatar
401
I got mine at Academy sports for $79.95.Fits the rack on my 500 ho just perfect.I used the straps and fastend with bolts and fender washers.It has a rubber seal on it to prevent leaks and it locks.
hondaRideRed
Apr 23, 2001 11:19 AM
WhoDatInDaMud
Mar 9, 2001 09:58 AM
Quicksand
Feb 28, 2001 07:46 PM
DryFly
Feb 26, 2001 08:42 AM
chop
Dec 31, 2000 09:03 PM
