Honda Foreman Toe-In
Old Dec 26, 2003 | 01:01 PM
Chilly's Avatar
Default Honda Foreman Toe-In
Has anyone noticed the toe-in setting being wrong on their Foreman? I have a 96 400 that was adjusted to the right amount, but was set for toe out instead of in. The service manual specifies 16 mm toe in with the wheels off the ground, mine was set for 15 mm toe out ! No wonder it was a bit twitchy at higher speeds.
After setting it correctly, the bike handles much better, turns tighter, etc. The wheels have to be off the ground to check it properly, because when the suspension is loaded with the weight of the bike, it is near zero, since the outer tie rod ends rise as the suspension compresses, decreasing the measured amount of toe in.
I talked with a friend who has a later version of the 450, and his was the same.
Chilly
Old Dec 26, 2003 | 08:12 PM
4rider's Avatar
how much is 16 mm in US form i need to reset mine to
Old Dec 27, 2003 | 01:27 PM
Chilly's Avatar
16 mm is approximately 0.63 inches or just over 5/8 of an inch
Chilly
Old Dec 27, 2003 | 01:36 PM
4rider's Avatar
thanx
NewGuy2481
Oct 6, 2015 05:54 AM
Johnny Mac
Sep 27, 2015 08:33 PM
stcspiderman
Sep 13, 2015 05:15 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
Jason Campbell
Sep 7, 2015 02:25 PM
