RIMS RIMS RIMS!!
What size rims would I need to get? I dont know anything about the bolt patterns or anything like that. The tires that would go on these rims are the:
Holeshot's in the rear, size 20-11-9
Holeshot XC's in the front, size 22-7-10
What exact rims (size) would I need for these tires on the z400?
Thank you,
Jesse
Thank you,
Jesse
Dragfameson
if those are the tires that you have or that you got you have to make sure you get 9 inch rims for the rear and make sure you get 10 inch for the front. That's probably the same size as your stock rims.
Just make sure that you get the last number of your tire size. (20X11-9) (22x7-10).
i'm pretty sure that the last number on the rim size is the width. I have 9x9's on my 250R which means the diameter is 9" and the width is 9". And i got 10x5's on the front of my 250R and they are 10" diameter and 5" wide.
I would go with the 9x9 for the rear because 9x8 would be 1" smaller in width and with your 20x11-9 you wouldn't want 3" wider tires on a 8" wide rim. And i would get the 10x5 for the front because 22x7-10 would fit perfect on those rims even with 2" more of rubber.
Sorry if i'm confusing you any.
1986 Honda 250R
Baldwin 310 cylinder
FMF exhaust with Power Core silencer
PEP Shocks
Tag X5 bars with Acrebis hand guards
Laeger steering stem
Burgard chrome a-arms
AC racing pro pegs, bumper, and grab bar
Houser swing arm
and a bunch of other stuff
1987 Suzuki LT250R
not nearly as much stuff on it as the Honda
1986 Honda 250R
PEP Shocks
Houser swing arm
1987 Suzuki LT250R
