what oil goes in the tranny of a scrambler
Old Dec 27, 2003 | 01:52 PM
chadscrambler's Avatar
Default what oil goes in the tranny of a scrambler
need to change the tranny oil in my scrambler 500. what would you guys recomend.. other than the expensive polaris brand??
Old Dec 27, 2003 | 03:10 PM
BigBadScrambler's Avatar
If you dont want the Polaris brand, then the only other substitute is Amsoil Series 2000 chaincase lube
Old Dec 27, 2003 | 09:59 PM
harescrambler's Avatar
75w-90w snethetic gear lube i use valvoline
Old Dec 27, 2003 | 11:19 PM
fishslab's Avatar
I'm assuming you mean the front dif. with the 75w-90. If not, all I can say is good luck. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Dec 28, 2003 | 09:59 AM
no it's for the transmission been using it for the past five years if you ever had one apart its a mini transfor case only a fork to move a smaller gear to get reverse two bigger gears with a thick like timing chain gears chain=gear lube
Old Dec 28, 2003 | 10:19 AM
ftwflh's Avatar
No more than you have to change it it is better to stay with the Polaris oil.
Old Dec 28, 2003 | 11:33 AM
modquad's Avatar
Gotta agree there. The Polaris fluid is a nice synthetic, that protects through all the crap we put these things through. Like Big Bad stated, the Amsoil is a suitable substitute. Change that at least once a year, more often if you're doing some serious deep muddin'. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 28, 2003 | 12:37 PM
stumpjumper400's Avatar
the only thing that isn't amsoil in my bike is the gas. i use their series 2000 chaincase lube in my tranny. hasn't done me wrong yet. in most cases using the manufacturer's oil you can't go wrong, i've never used the polaris synthetic except when the bike was new so i can't really make a comment on it. i run amsoil in everything i own. that's my opinion for what it's worth, and i'ts just an opinion. use a compatible product that you feel comforatable with. if i weren't using amsoil i'd probably use the polaris stuff.
steve
Old Dec 28, 2003 | 02:00 PM
modquad's Avatar
Last winter I went through the Sports trans, just for preventative. Changed out the chain, was a bit stretched, and removed that huge reverse gear. I've made sure to change it at least once a year, and that payed off.....virtually no wear noted. Even pushing almost 3 times the designed HP through it for this long....da stuff works. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 28, 2003 | 04:55 PM
pamotorman's Avatar
polaris trans oil has moly in it for better lubrication and i would not use any that does not have moly because if it was not needed polaris would not put it in there
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
